mel15's avatar
mel15
Star
Feb 06, 2021
Nighthawk(R) X4s R7800 main router , connected 2 other routers but want one login to controll all
I have 3 Routers.  My Main Router is R7800 Nighthawk it is connected to my modem on my main floor in center of house.          It also has 3 other devices connected via ethernet cables.  In additi...
  • plemans's avatar
    Feb 06, 2021
    You can leave the ssid's the same or change them so you know which network is which.
    None of those routers are mesh systems so your devices will tend to stay connected and not roam like a mesh system would.
    Benefit to a different ssid is that its easy enough to change. If the ssids are all the same, you disconnect the wifi and reconnect and hope it connects to the closer device.
    Some newer devices will roam or can have an app installed to program in auto roaming protocols
