aprayiii
Jan 13, 2022Star
Nighthawk(R) X4S R7800 MD5 Verify Error
Getting an MD5 Verify error when trying to install new firmware. I saw some old posts about this but nothing recent. Any advice appreciated.
- Mar 18, 2022
Wooohooo! Mine worked correctly. And BTW I did NOT have to do any sort of reset, just went to the update and it worked fine from a Chrome session connected wirelessly.
Kitsap
Jan 13, 2022Master
Are you updating via wi-fi or over a direct ethernet connection? Strongly recommend the direct ethernet connection.
Download a fresh copy of the firmware and make sure you remove the .img file from the downloaded zip file.
