aprayiii
Jan 13, 2022Star
Nighthawk(R) X4S R7800 MD5 Verify Error
Getting an MD5 Verify error when trying to install new firmware. I saw some old posts about this but nothing recent. Any advice appreciated.
- Mar 18, 2022
Wooohooo! Mine worked correctly. And BTW I did NOT have to do any sort of reset, just went to the update and it worked fine from a Chrome session connected wirelessly.
Jan 13, 2022Guru - Experienced User
Also try using Firefox or MS Edge browser to send FW files.
- aprayiiiJan 14, 2022Star
These other browsers did not work via wifi.
- FURRYe38Jan 14, 2022Guru - Experienced User
Its recommended that you not update router FW via wifi and use a wired PC and web browser to update FW on routers:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Yes, understood, have been doing it at my own risk. Just was pointing out that is has been working :)
