aprayiii
Jan 13, 2022Star
Nighthawk(R) X4S R7800 MD5 Verify Error
Getting an MD5 Verify error when trying to install new firmware. I saw some old posts about this but nothing recent. Any advice appreciated.
- Mar 18, 2022
Wooohooo! Mine worked correctly. And BTW I did NOT have to do any sort of reset, just went to the update and it worked fine from a Chrome session connected wirelessly.
northwind79
Jan 14, 2022Star
Same, I'm just using the "Click here to get it" button in the GUI. Haven't tried downloading it and installing it manually yet.
northwind79
Jan 14, 2022Star
I just did the manual update over a directly connected host, went through fine.
- FURRYe38Jan 14, 2022Guru - Experienced User
Theres a new version of FW out for the R7800.
