aprayiii
Jan 13, 2022Star
Nighthawk(R) X4S R7800 MD5 Verify Error
Getting an MD5 Verify error when trying to install new firmware. I saw some old posts about this but nothing recent. Any advice appreciated.
- Mar 18, 2022
Wooohooo! Mine worked correctly. And BTW I did NOT have to do any sort of reset, just went to the update and it worked fine from a Chrome session connected wirelessly.
northwind79
Jan 14, 2022Star
I just did the manual update over a directly connected host, went through fine.
Jan 14, 2022Guru - Experienced User
Theres a new version of FW out for the R7800.
