aprayiii
Jan 13, 2022Star
Nighthawk(R) X4S R7800 MD5 Verify Error
Getting an MD5 Verify error when trying to install new firmware. I saw some old posts about this but nothing recent. Any advice appreciated.
- Mar 18, 2022
Wooohooo! Mine worked correctly. And BTW I did NOT have to do any sort of reset, just went to the update and it worked fine from a Chrome session connected wirelessly.
jmidway22
Feb 17, 2022Guide
Also getting a md5 error when using the web interface to update the firmware from .80 to .90. I read through the threads but I didn't see anything that solved this.. also the GUI update doesn't seem to work either with same MD5 error.
I manually downloaded it from netgear and uploading to the router which worked but didn't see the gui update in the support repository.
- FURRYe38Feb 17, 2022Guru - Experienced User
Try a factory reset and walk thru the setup wizard with a wired PC and web browser.
- jmidway22Feb 17, 2022Guide
Yeah that could work :) but its just a hail marry guess. thats what I would tell people to do when I was in high school doing tech support and didn't have a clue why our product wasn't working correctly.
Also why does it matter if the pc is hardwired? When you login to the router's web interface and kickoff its firmware update process, it shouldn't be relying on your PCs connection to do that. Should be going directly from the router to netgear's firmware repository to download? or am i missing something
- northwind79Feb 17, 2022Star
I've been using the same method for years. Advanced menu, click Administration, then Firmware Update. If the new firmware update available isn't already there, I click "Check Firmware" and get the info. Currently running V1.0.2.90 without issue after the manual update off a wired connection. I'm not sure why the MD5 checksum for the firmware package pulled down via the GUI does not match what is expected... Maybe a storage issue is truncating the file which would alter the MD5 checksum, who knows.
After seeing your post, I decided to check and see if there were any new updates, turns out there's a GUI update... Wouldn't you know it, but I click "Yes" on the GUI and hit the MD5 checksum error again.
New firmware is found. Do you want to update the firmware? (Yes) (No) Current GUI Language Version: V1.0.0.361 New GUI Language Version: V1.0.0.423 Release Notes: I'll run the manual update and see what happens. It's a minor annoyance, not the end of the world, but maybe it's the universe telling me that it is time to upgrade the hardware, IDK. Best of luck to you.
--Smartypants
