aprayiii
Jan 13, 2022Star
Nighthawk(R) X4S R7800 MD5 Verify Error
Getting an MD5 Verify error when trying to install new firmware. I saw some old posts about this but nothing recent. Any advice appreciated.
- Mar 18, 2022
Wooohooo! Mine worked correctly. And BTW I did NOT have to do any sort of reset, just went to the update and it worked fine from a Chrome session connected wirelessly.
northwind79
Feb 17, 2022Star
I've been using the same method for years. Advanced menu, click Administration, then Firmware Update. If the new firmware update available isn't already there, I click "Check Firmware" and get the info. Currently running V1.0.2.90 without issue after the manual update off a wired connection. I'm not sure why the MD5 checksum for the firmware package pulled down via the GUI does not match what is expected... Maybe a storage issue is truncating the file which would alter the MD5 checksum, who knows.
After seeing your post, I decided to check and see if there were any new updates, turns out there's a GUI update... Wouldn't you know it, but I click "Yes" on the GUI and hit the MD5 checksum error again.
| New firmware is found. Do you want to update the firmware? (Yes) (No) | |
| Current GUI Language Version: | V1.0.0.361 |
| New GUI Language Version: | V1.0.0.423 |
| Release Notes: |
I'll run the manual update and see what happens. It's a minor annoyance, not the end of the world, but maybe it's the universe telling me that it is time to upgrade the hardware, IDK. Best of luck to you.
--Smartypants
aprayiii
Feb 17, 2022Star
northwind79 wrote:I've been using the same method for years. Advanced menu, click Administration, then Firmware Update. If the new firmware update available isn't already there, I click "Check Firmware" and get the info. Currently running V1.0.2.90 without issue after the manual update off a wired connection. I'm not sure why the MD5 checksum for the firmware package pulled down via the GUI does not match what is expected... Maybe a storage issue is truncating the file which would alter the MD5 checksum, who knows.
New firmware is found. Do you want to update the firmware? (Yes) (No) Current GUI Language Version: V1.0.0.361 New GUI Language Version: V1.0.0.423 Release Notes:
--Smartypants
Yes, I am the OP on this thread and I also receive the MD5 error with the language version update.
- northwind79Feb 17, 2022Star
Curiously enough, I am not seeing this GUI language version update as available from the Netgear download center at this time. Hopefully the next version will have it baked in.
--Smartypants
