aprayiii
Jan 13, 2022Star
Nighthawk(R) X4S R7800 MD5 Verify Error
Getting an MD5 Verify error when trying to install new firmware. I saw some old posts about this but nothing recent. Any advice appreciated.
- Mar 18, 2022
Wooohooo! Mine worked correctly. And BTW I did NOT have to do any sort of reset, just went to the update and it worked fine from a Chrome session connected wirelessly.
aprayiii
Feb 17, 2022Star
northwind79 wrote:I've been using the same method for years. Advanced menu, click Administration, then Firmware Update. If the new firmware update available isn't already there, I click "Check Firmware" and get the info. Currently running V1.0.2.90 without issue after the manual update off a wired connection. I'm not sure why the MD5 checksum for the firmware package pulled down via the GUI does not match what is expected... Maybe a storage issue is truncating the file which would alter the MD5 checksum, who knows.
After seeing your post, I decided to check and see if there were any new updates, turns out there's a GUI update... Wouldn't you know it, but I click "Yes" on the GUI and hit the MD5 checksum error again.
New firmware is found. Do you want to update the firmware? (Yes) (No) Current GUI Language Version: V1.0.0.361 New GUI Language Version: V1.0.0.423 Release Notes:
I'll run the manual update and see what happens. It's a minor annoyance, not the end of the world, but maybe it's the universe telling me that it is time to upgrade the hardware, IDK. Best of luck to you.
--Smartypants
Yes, I am the OP on this thread and I also receive the MD5 error with the language version update.
northwind79
Feb 17, 2022Star
Curiously enough, I am not seeing this GUI language version update as available from the Netgear download center at this time. Hopefully the next version will have it baked in.
--Smartypants
