aprayiii
Jan 13, 2022Star
Nighthawk(R) X4S R7800 MD5 Verify Error
Getting an MD5 Verify error when trying to install new firmware. I saw some old posts about this but nothing recent. Any advice appreciated.
- Mar 18, 2022
Wooohooo! Mine worked correctly. And BTW I did NOT have to do any sort of reset, just went to the update and it worked fine from a Chrome session connected wirelessly.
Mar 04, 2022Guru - Experienced User
Can you all re-check this? I got word from NG that this was fixed on there side.
northwind79
Mar 04, 2022Star
Already on the newer firmware, still get the MD5 error for the GUI language update. Have a case open with NG they wanted me to factory reset the thing, figure I'll try it over the weekend.
