aprayiii
Jan 13, 2022Star
Nighthawk(R) X4S R7800 MD5 Verify Error
Getting an MD5 Verify error when trying to install new firmware. I saw some old posts about this but nothing recent. Any advice appreciated.
- Mar 18, 2022
Wooohooo! Mine worked correctly. And BTW I did NOT have to do any sort of reset, just went to the update and it worked fine from a Chrome session connected wirelessly.
Mar 04, 2022Guru - Experienced User
Can you all re-check this? I got word from NG that this was fixed on there side.
dhe
Mar 05, 2022Guide
Still no luck, I'm afraid. Currently running firmware version V1.0.2.84 and GUI language version V1.0.0.422, and the Firmware Update Assistant is still giving me the MD5 verification error. Unfortunately the FUA shows here both updates on the same page and doesn't provide any means to select one of them individually, so there's no way I can tell which of the two actually causes this.
- FURRYe38Mar 05, 2022Guru - Experienced User
OK thanks for letting us know. I got same as well on v.90...still happening. I've passed this on to NG.
- FURRYe38Mar 17, 2022Guru - Experienced User
Everyone,
Please factory reset your R7800 router and walk thru the setup wizard. The GUI should update correctly now:
Mine updated with out error today.
- aprayiiiMar 18, 2022Star
