aprayiii
Jan 13, 2022Star
Nighthawk(R) X4S R7800 MD5 Verify Error
Getting an MD5 Verify error when trying to install new firmware. I saw some old posts about this but nothing recent. Any advice appreciated.
- Mar 18, 2022
Wooohooo! Mine worked correctly. And BTW I did NOT have to do any sort of reset, just went to the update and it worked fine from a Chrome session connected wirelessly.
Mar 05, 2022Guru - Experienced User
OK thanks for letting us know. I got same as well on v.90...still happening. I've passed this on to NG.
Mar 17, 2022Guru - Experienced User
Everyone,
Please factory reset your R7800 router and walk thru the setup wizard. The GUI should update correctly now:
Mine updated with out error today.
- aprayiiiMar 18, 2022Star
- FURRYe38Mar 18, 2022Guru - Experienced User
Glad it's working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- aprayiiiMar 18, 2022Star
Thanks! Done!
