Goldenretrieve's avatar
Oct 04, 2024
Nighthhawk R9000 shows no internet connection but connection is up
I have 3 Nighthawk R9000 devices running in WP mode.
One of the three still works ok.
In the last 2 days 2 of the devices stopped sending me a daily log.
When investigating I found that the two devices showed that they were not connected to the internet, yet connected devices (like the one I'm using now) successfully connect to the internet via the routers that show "Internet Error not connected" on the initial login screen.
I am unable to manually send the logs even though nothing in my login parameters have changed.
Also I am unable to connect to the netgear ntp server,  The time on the ntp screen shows 2022.
I have tried rebooting both malfunctioning routers.
All devices are behind an OpenSense firewall.
Any ideas?
