Mili's avatar
Mili
Guide
Sep 24, 2020
Nighthwk X6 R8000 V1.0.4.58_10.1.72 firmware update causing frequent disconnects
Again Netgear releases an update that consistently causes dropped internet connections.
Anyone know of a hotfix or what to do to stop this from happening?
Thanks in advance !
M
  •  did you try a factory reset and manually reinstalling it (not from backup)?
    sometimes old settings carried over can cause issues and if there's issues after a firmware change, thats a reasonable first step.
    If it doesn't help, you can downgrade the firmware.
  • plemans's avatar
    • Mili's avatar
      Mili
      Guide
      Definitely not my ideal solution, but thanks, will give a try.
    • Mili's avatar
      Mili
      Guide
      seems to be working ok. Hopefully it will last ! lol
      thanks again!
