susanna
Aug 09, 2015Aspirant
Nigthawk X8 / R8000 Connected Wifi, but no internet
Hi -- I've had a little over two weeks the X6 router connected to a SB6183 and I've noticed that on the 2.4 and 5ghz bands, my devices show connected, but I can't access the internet. I have to turn ...
- Aug 10, 2015
Hi susanna,
It seems like the router is still using an old firmware. You can try updating the firmware to the latest one. You may check the links below on how to update the firmware manually and automatically. Reset the router after updating the firmware.
http://downloadcenter.netgear.com/en/product/R8000#searchResults
-Router Firmware Update using the NETGEAR Genie Software:
http://kb.netgear.com/app/answers/detail/a_id/23856
-Installing the latest firmware on a NETGEAR router:
http://kb.netgear.com/app/answers/detail/a_id/23442/related/1
-Upgrading your Router's Firmware Manually:
http://kb.netgear.com/app/answers/detail/a_id/23960/related/1
JamesGL
Community Team
Scotsmist
Sep 13, 2015Guide
Sue did you manage to resolve the netgear R8000 not showing internet as I have exactly the same problem please see attached image.
It also says that no ethernet cable is plugged into the router internet port but this is wrong as it is connecrted and it works when I connect my other router a link-sys & also a tp-link.
It is reporting no internet but this is false reporting.
if you resolved yours it maybe something similar?
Thanks Hugh
notredw
Jan 20, 2016Aspirant
I have the same problem, same window shows no internet. most wifi work but can no longer access vudu and my samsung extender use for the cells at home. Can someone help me with this problem. Dis you fix your problem?
