susanna
Aug 09, 2015Aspirant
Nigthawk X8 / R8000 Connected Wifi, but no internet
Hi -- I've had a little over two weeks the X6 router connected to a SB6183 and I've noticed that on the 2.4 and 5ghz bands, my devices show connected, but I can't access the internet. I have to turn ...
- Aug 10, 2015
Hi susanna,
It seems like the router is still using an old firmware. You can try updating the firmware to the latest one. You may check the links below on how to update the firmware manually and automatically. Reset the router after updating the firmware.
http://downloadcenter.netgear.com/en/product/R8000#searchResults
-Router Firmware Update using the NETGEAR Genie Software:
http://kb.netgear.com/app/answers/detail/a_id/23856
-Installing the latest firmware on a NETGEAR router:
http://kb.netgear.com/app/answers/detail/a_id/23442/related/1
-Upgrading your Router's Firmware Manually:
http://kb.netgear.com/app/answers/detail/a_id/23960/related/1
JamesGL
Community Team
JamesGL
Sep 14, 2015NETGEAR Employee Retired
Hi Scotsmist,
Welcome to Community!
Do you have the latest firmware installed on your router? If not, you can check the support site for the lates firmwares.
JamesGL
Community Team
Scotsmist
Sep 27, 2015Guide
Thanks James but the fault was not the firmwase (I had the latest) it turned out to be a netgear manufacturing fault, this will be the second faulty unit!
