OMFGjustHF
May 19, 2021Aspirant
Nigthhawk AC2300 R7000P Keep crashing several times a day
Hello everyone I bought a AC2300, but lately it keeps crashing out of nowhere. It fixes by restarting the router, but it is extremly annoying while playing online or working from home. I have...
May 23, 2021Guru - Experienced User
OMFGjustHF wrote:Hey Plemans
Thank you for your reply.
The crash is that the internet stop working on both wired and wireless devices.----and what are the led's doing when it happens (color, blinking, solid, all of them)
It doenst auto reboot. I dont get any message with "connected, no internet). It allways works to reboot after 5 minutes.---reboot the router? or the fibernet box?
The router is connected directly to fibernet box. What model fibernet box is it plugged into?
I have btw tested that it is not the connection, because I can plugin my wired computer without thr breakdowns.---Plug it into the router? into the fibernet box? what are you plugging it into?
OMFGjustHF
May 24, 2021Aspirant
The colors variets under a crash.
Sometimes alle goes black except power, which is orange.
Other times all lights are white (alittle flashy) except one light which is orange.
reboot the router? or the fibernet box? When i reboot the router
What model fibernet box is it plugged into? I have no clue. It is the stardard box mounted by Ewii, (Danish fibernet company) directly into the wall. My house is only 1 year old and the connection work fine until 4 month ago.
Plug it into the router? into the fibernet box? what are you plugging it into? Fiberbox to computer, whitout crashes.
