NightHawk_mess
Feb 09, 2021Follower
NigthHawk Firmware failure
Night hawk does firmware update and fails- no inrternet- no access to the router software via either ethernet cable, wiFi or app. Hard reset does not work. Power cycle does not work. Technical sup...
Feb 10, 2021Guru - Experienced User
What are the leds on it doing?
What firmware were you updating to?
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
