Propsero
Dec 19, 2022Aspirant
Nintendo Switch Cannot Connect to Wifi on Nighthawk X6 (R8000)
Hi Netgear community. New here and looking for advice. All of a sudden, my kids' Nintendo Switch lites cannot connect to the WiFi at home. I have rebooted the Virgin hub (modem only mode) and the N...
Dec 21, 2022Guru - Experienced User
What security mode is set on the router?
- PropseroDec 22, 2022Aspirantwpa2 psk is the current security method(?) according to the Netgear app.
- FURRYe38Dec 22, 2022Guru - Experienced User
Is that WPA2 AES or TPIK?
What happens if you set NONE for security temporarily and try to connect the Switch device to the router?
Re-enable WPA2 and AES after testing this. MIght try WPA and TPIK and see...
