ACStoudt
May 24, 2021Aspirant
Nitehawk Internet drops and Qos downstream setting
Arris SURFBoard SB6141, is connected to Netgear Nitehawk AC1750, model R6700v2. Five devices are connected to the router via WiFi. Two Rokus, one computer, an IPhone, and a printer. I am having int...
michaelkenward
May 25, 2021Guru - Experienced User
What firmware version do you have on the R6700v2?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
ACStoudt wrote:
Two, how do I increase the Downstream QoS for my streaming devices?
How fast is your Internet service? Anything much higher than 200 Mbps and QoS just slows things down. What makes you think that you need it?
- ACStoudtMay 25, 2021Aspirant
Router Firmware Version V1.2.0.76_1.0.1
Xfinity/Comcast Blast. Up to 200Mbps download. Up to 10 Mbps upload.
I just thought that increasing the Download Qos for my streaming device (Roku) would stop the death spiral of buffering (when the internet is working)
- michaelkenwardMay 25, 2021Guru - Experienced User
You have the latest firmware.
That is way faster than you need for streaming and for most normal activities.
What happens when the only thing happening is the streaming?
How is all this stuff connected? Wifi? Wired is always faster.
Manual says to log in to the router and Select ADVANCED > Setup > QoS Setup > Downstream QoS. I logged into the router, via WiFi, and cannot find anywhere to tweak the Downstream QoS.
From that bit it seems that you are trying to configure your device using a mobile app. Not a good idea. As you have discovered, something are not possible on the app, including QoS tweaks. The apps are for simple stuff. Anyone with a bit of knowledge soon abandons that way in.
The fact that you lose the Internet from time to time suggests that you might like to do a bit of troubleshooting before worrying about QoS.
- ACStoudtMay 26, 2021Aspirant
Same. Even when just watching YouTubeTV, internet drops out and the app tells me that it's lost internet or the app just closes.
Ethernet cable connects modem to router. All 5 devices connect via WiFi. Wired would be great but I only have one output from the modem.
I'm logging in to the router from my computer, via WiFi. Do you think that it would be different if I log in via hardwired from my computer?
Agreed. I'm thinking that I might have to buy another router from BestBuy and take it back if the problem doesn't go away. Any shopping suggestions?
