blackpawn
Sep 30, 2021Aspirant
No 5GHz on Nighthawk R8500
Using Firmware V1.0.2.154 So maybe a year ago I started having problems with the 5Ghz networks, the would disappear and I had to reboot the router to get them back. After a firmware update 6? mon...
- Sep 30, 2021
Ah I found under Advanced > Wireless Settings the 5GHz radios had the checkbox disabled. I clicked to enable and restarted and the LED lights are on the the 5GHz networks are working again.
blackpawn
