geigervicki
Oct 05, 2021Follower
no accss to Nighthawk app.
I can not acess my WIFi settings using the NIghthawk Appl.I gegt to the admin login portion and type in my password and an error message pops up saying log on timedout. I hae tried resetting the adm...
Brettmcm
Oct 05, 2021Apprentice
Use a different device, and log into the app, select "anywhere access" and you'll be to access the device with that option. The only other choice is to loging to the router through a computer that's hardwired to the router using the 192.168.1.1 address.
I know super annoying and for what they charge you would think this would be something they would fix, don't bother asking them they'll just say, "theres nothing wrong with the app", yeah Ok that's why everyone is having the exact same problem.
Oct 05, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Nighthawk App product. Most of the people who watch that forum are more likely to have experience with Nighthawk App and know how to work it better than those of us who follow this "router" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
Good Luck.
