chucker8
Jan 19, 2023Follower
No antennas for Nighthawk AC1900 Model R7000
Hi,
I received a Nighthawk AC1900 Model R7000 router, but I didn't receive the antennas.
Will the wifi on the router still work?
thanks
1 Reply
Barely, you can connect any antenna that has the screw on connections and will work. I had to do the same to mine as some how I lost the antennas so I grab some from a different router. Works.
