sshukla's avatar
sshukla
"No Disk." Error in ReadySHARE
Hello,
I'm getting a "No Disk." error when I have my NTFS USB hard disk directly connected into the usb 3.0 port on the R7000 router. I was working for several months but I had to connect the hard disk directly to my computer to copy and move some files around. Once I reconnected it to the router it was no longer recognized. I have restarted the router several times and the firmware seems to be up to date.
Thoughts?
Thanks,
Sumit
  • Hi sshukla,
    Have you performed a factory reset on the router?
    JamesGL
    Community Team
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi sshukla,
    JamesGL
    Community Team
    • sshukla's avatar
      sshukla
      I performed a factory reset and the issue was resolved--thanks for the suggestion. I still do not know what happened and wish it was possible to resolve w/o factory reset.
      thanks,
      s
      • JamesGL's avatar
        JamesGL
        Hi Sshuka,
        Glad to know it works. Feel free to provide update if ever it happens again.
        JamesGL
        Community Team
