gaffers's avatar
gaffers
No DSL Port
Have I made an error. I’ve just upgraded my router and there is no DSL port. How do I connect my router? My current Nighthawk has a DSL port. Thanks
  • Is your old router a combo device that has a moder/router functionality?  If so you will need a DSL modem to connect to your ISP then you will connect that to your new router.
  • > [...] I've just upgraded my router [...]
       Why?  To this?:
    > Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
    > [...] My current Nighthawk has a DSL port. [...]
       Has it also a model number?  Look for "Model" on the product label.
    > [...] How do I connect my router?
       You could connect it to your old (unspecified) "My current
    Nighthawk", which, presumably, includes a DSL modem.  Or you could get a
    new DSL modem, and use that.
       Configure your old (unspecified) "My current Nighthawk" as a modem
    only, or else configure your new R8000 as a wireless access point.
       Visit http://netgear.com/support , put in your (actual) model number,
    and look for Documentation.  Get the User Manual (at least).  Read.
    Repeat as required.
