bobcolby
Dec 16, 2015Aspirant
No email connectivity after upgrading to V94 FW on R7500
Upgraded my Nightawk X4 R7500 WiFi Ruter to V1.0.0.94 FW, V1.0.0.231 GUI. Did the factory reset as intructions indicated. I could log in to router, reset my admin password, looked at connectivity, ...
- Dec 17, 2015
If other internet access is working (e.g. web browsing) through wifi then your router is fine. Your router works at the packet level and doesn't care about the contents. Email and web all look the same to the router. The only exception is if you have set up some firewall rules that block specific ports: this could then impact email but not web. However, unless you've specifically set this up, it won't be the case. Therefore, if it's only email you have problems with, look to your ISP or email settings on your laptop. It's not your router.
bobcolby
One more thing to add: NETGEAR Genie does nt work. Reloaded it to desktop, no difference. Windows 10 says the program has stopped working. Not sure if this has any connection to the email issue. I can still see everything via routerlogin just fine.
- rpoffenDec 16, 2015Virtuoso
The general consensus has been that running the Genie SW on a PC actually causes problems for the router. Better off just un-installing it.
- Retired_MemberDec 17, 2015
My Comcast POP ports
incomming 110 mail.comcast.net
outgoing 587 smtp.comcast.net
Comcast has made some changes for IMAP check their site
