bobcolby
Dec 16, 2015Aspirant
No email connectivity after upgrading to V94 FW on R7500
Upgraded my Nightawk X4 R7500 WiFi Ruter to V1.0.0.94 FW, V1.0.0.231 GUI. Did the factory reset as intructions indicated. I could log in to router, reset my admin password, looked at connectivity, ...
- Dec 17, 2015
If other internet access is working (e.g. web browsing) through wifi then your router is fine. Your router works at the packet level and doesn't care about the contents. Email and web all look the same to the router. The only exception is if you have set up some firewall rules that block specific ports: this could then impact email but not web. However, unless you've specifically set this up, it won't be the case. Therefore, if it's only email you have problems with, look to your ISP or email settings on your laptop. It's not your router.
PEHowland
Dec 17, 2015Apprentice
bobcolby
Dec 17, 2015Aspirant
Thanks for the tip. Investigating further on thi, the problem turned out to be the Avast mail shield not playing well with the router after the update. It was blocking the mail connections. Seeing the mail shield sucking up lots of CPU even though there was no mail was the smoking gun. Turned off all Avast shields and mail started pouring in. Rebooted router and avast, restored shields and all is well. No server settings changed (as expected). Thanks for the pointers.
- PEHowlandDec 17, 2015Apprentice
Great! Glad it helped.
