scacountor
Jan 24, 2021Initiate
No Firmware Update Option
New Purchase. Had a Nighthawk I never had issues with which is the reason I bought this....off to a rocky start with this one. No Option to update firmware in either the webclient (Advanced>admin) or...
- Jan 24, 2021
> [...] Had a Nighthawk I never had issues with [...]
Thanks for the detailed description. I'll guess that, whatever it
was, it did _not_ include a DOCSIS cable-TV modem.> [...] No Option to update firmware [...]
> Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Yup.
antinode
Jan 24, 2021Guru
Yup.
- scacountorJan 24, 2021InitiateAwesome..didn't see that in the manual..I don't understand why they have a section on updating firmware in the manual...when you can't.
Also, the versions need to be updated..I have Spectrum but it displays an older version on th doc.
Thanks again.
