scacountor
Jan 23, 2021Initiate
No Firmware Update Option
New Purchase. Had a Nighthawk I never had issues with which is the reason I bought this....off to a rocky start with this one. No Option to update firmware in either the webclient (Advanced>admin) or...
- Jan 23, 2021
> [...] Had a Nighthawk I never had issues with [...]
Thanks for the detailed description. I'll guess that, whatever it
was, it did _not_ include a DOCSIS cable-TV modem.> [...] No Option to update firmware [...]
> Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Yup.
antinode
Jan 23, 2021Guru
Yup.
scacountor
Awesome..didn't see that in the manual..I don't understand why they have a section on updating firmware in the manual...when you can't.
Also, the versions need to be updated..I have Spectrum but it displays an older version on th doc.
Thanks again.
Thanks again.
