rsteve1
Dec 27, 2020Initiate
No firmware updates, even when a Netgear email says there is one
Dec 28, 2020Guru - Experienced User
What device model do you have?
What version of the firmware are you on?
go to the support site https://www.netgear.com/support/ type in your model and it'll take you to your devices support site. here you can compare which version you're on to whats released. (sometimes the auto-update version can be newer)
- rsteve1Dec 28, 2020Initiate
Thank you for your guidance about the support site. My rounter seems to be working fine and I hesitate to take some of the steps mentioned at the support site. My WNDR4500v3 is working fine, I'm just worried about hacking because I don't have the latest fixes because the firmware hasn't changed since January, even though I've had an email that tells me there is an update. I've been to the advanced section of my router's site to check for updates (about every 2 months) and there aren't any.
Thanks again for your quick reply and for sharing your knowledge.
Ron
- michaelkenwardDec 28, 2020Guru - Experienced User
A device that old, dating back to 2013, is approaching "EOL" (end of life) as far as Netgear is concerned. It was never that sophisticated. It doesn't seem to support 5 GHz wifi. But if it works for you, fine.
I don't know what "the advanced section of my router's site" is, but for the latest firmware visit the support pages on the Netgear site.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
