Stelpie
Nov 22, 2016Aspirant
No internet access after enabling parental controls
I have setup the parental controls on my router from my computer, when it is enabled I don't have internet access on that computer every other computer, phone or tablet works. I have the bypass accou...
- Apr 19, 2017
Hi JamesGL,
Thank you for your reply,
I've been a bit frustrated with this problem and decided to switch to a different router brand but that was not really a success, I hooked up my router again yesterday and wanted to give it an other shot
At first I had the same problem, enabling LPC and no Internet connection on my computer, every other computer and device works fine btw.
So I started to check what is the difference between my computer and an other one, both have the same windows version. Then I realised that I (long time ago) entered an different DNS server address in my adapter settings, so I changed it to default again and everything works fine again
Hope this might help someone else as well
Thanks again
JamesGL
Nov 30, 2016NETGEAR Employee Retired
Hi Stelpie,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
JamesGL
Community Team
Stelpie
Apr 19, 2017Aspirant
Hi JamesGL,
Thanks again
