Exyle's avatar
Exyle
No Internet Access After Factory Reset
After having intermittent internet issues and random disconnects for days, I did a factory reset on my Nighthawk router. I followed the instructions on my Nighthawk app to re-activate the router afte...
  • Exyle's avatar
    Jun 30, 2021
    Well, I disconnected the ethernet cable from my PC and reconnected it to the router. I then used the PC to access the router and set it up, and now it works! I would recommend NOT using the Nighthawk app...it appears to have various problems.
