Exyle
Jun 30, 2021Aspirant
No Internet Access After Factory Reset
After having intermittent internet issues and random disconnects for days, I did a factory reset on my Nighthawk router. I followed the instructions on my Nighthawk app to re-activate the router afte...
- Jun 30, 2021
Well, I disconnected the ethernet cable from my PC and reconnected it to the router. I then used the PC to access the router and set it up, and now it works! I would recommend NOT using the Nighthawk app...it appears to have various problems.
nate28677
Jul 01, 2021Aspirant
Nighthawk x6 AC3000 tri band wifi router R7850
Router worked great until I updated with App. Once updated now it says cannot find router. Went thru all the steps shown, same results.
If I knew this would happen I would not have updated app.
My router has blinking power light and 2 amber lights on USB
I saw the comment that the gentleman made about doing it from his PC. Can someone give me the steps on doing that.
Thank you in advance
antinode
Jul 01, 2021Guru
> My router has blinking power light [...]
Potentially informative:
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for the
LED descriptions and "Troubleshoot".
If you have a flashing power indicator, then you may be a candidate
for the TFTP recovery scheme. See, for example:
https://community.netgear.com/t5/x/x/m-p/1622096#M102004
> [...] from his PC. Can someone give me the steps on doing that.
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions. (In the User Manual, look for "firmware", and,
especially, for a topic like "Manually Upload Firmware to the Router".)
When that fails because of a deficient User Manual, try:
