waynelloyd
May 26, 2018Guide
No internet access after installing firmware update 1.0.4.18
Soon after installing firmware update 1.0.4.18 on my Nighthawk R8000 webpages failed to load from all connected clients
My ISP tested my internet service and no issues where reported
Inbound con...
- Nov 08, 2018
I installed the latest firmware update V1.0.4.28_10.1.54 and enabled standard parental controls and so far so good internet is working fine
The update did fail to install a few times over wifi but I got it to sucessfully install after I turned off my nighthawk wifi extender EX7300
I updated from V1.0.4.18_10.1.49 to V1.0.4.28_10.1.54 and noticed I had to enable the smart connect feature again after the update got installed
Other issues are reported on this thread that I didn't experience
I opened this discussion for internet access issues with V1.0.4.18_10.1.49 and after I installed the latest firmware V1.0.4.28_10.1.54 my internet access issues (with standard parental contols enabled) seem to be fixed.
SK2
Jun 08, 2018Guide
Do we have a resolution that can be shared? I turned off my parental controls and I'm still having issues. Are we just rolling back to the previous version of firmware?
ghentj
Jun 08, 2018Star
After I re-installed 4.18, i did a factory reset, and re-entered all my configuration manually (not using the saved config). Parental controls are off, using opendns still. I've had no conectivity problems, even turned on smart connect, and things have been very stable (7 days since last reboot). my 2.4 and 5.0 ssid names are different. Wired internet is also good.
I am having problems with usb shared names changing back to what they defaulted to though. not sure what triggers the change back.
- TerryPhJun 08, 2018Virtuosoghent
---Parental controls are off, using opendns still --- This is confusing. Do you mean you are still activating OpenDNS parental control service on the router?- ghentjJun 08, 2018Star
TerryPh wrote:
ghent
---Parental controls are off, using opendns still --- This is confusing. Do you mean you are still activating OpenDNS parental control service on the router?No, so under the parental control section, it is turned off. Under the Domain Name Server (DNS) Address section, I am using Primary, 208.67.222.222 and secondary 208.67.220.220, which are the OpenDNS servers - see the netgear section on this link: https://use.opendns.com/
This uses their DNS servers, but it does not enable parental control if it is turned off in the parental control section. With the parental controls turned off, it's been working as far as I can tell. With the parental controls on (which also uses the OpenDNS servers along with your account login info), it would do what everyone else seems to be experiencing with the internet no longer working
The reason I want to use OpenDNS even without the parental controls is that I don't want to use my ISP's DNS Servers.
Hope this helps.
- TerryPhJun 08, 2018VirtuosoThanks for clarification on using NG openDNS.
The router should be stable, provided that you don't have USB drive(s) attached + DLNA on. Under this condition, my router crashed after a few days.
I'm running my router under minimum stress condition, and it has been stable past 3 days, to be exact. Hope it stays stable past one-week mark...
Best,
