waynelloyd
May 26, 2018Guide
No internet access after installing firmware update 1.0.4.18
Soon after installing firmware update 1.0.4.18 on my Nighthawk R8000 webpages failed to load from all connected clients
My ISP tested my internet service and no issues where reported
Inbound con...
- Nov 08, 2018
I installed the latest firmware update V1.0.4.28_10.1.54 and enabled standard parental controls and so far so good internet is working fine
The update did fail to install a few times over wifi but I got it to sucessfully install after I turned off my nighthawk wifi extender EX7300
I updated from V1.0.4.18_10.1.49 to V1.0.4.28_10.1.54 and noticed I had to enable the smart connect feature again after the update got installed
Other issues are reported on this thread that I didn't experience
I opened this discussion for internet access issues with V1.0.4.18_10.1.49 and after I installed the latest firmware V1.0.4.28_10.1.54 my internet access issues (with standard parental contols enabled) seem to be fixed.
ghentj
Jun 12, 2018Star
At the cost of turning off the parental controls, it's been stable for me. Others have tried the same thing though, and it did not make it more stable for them.
I did do a factor reset and manually enter my many changes back in.
jhdooley2
Jun 12, 2018Aspirant
So you left the parental controls off indefinitely?
Or were you able to turn them back on after the factory reset and reinstall of the updates?
