waynelloyd
May 26, 2018Guide
No internet access after installing firmware update 1.0.4.18
Soon after installing firmware update 1.0.4.18 on my Nighthawk R8000 webpages failed to load from all connected clients
My ISP tested my internet service and no issues where reported
Inbound con...
- Nov 08, 2018
I installed the latest firmware update V1.0.4.28_10.1.54 and enabled standard parental controls and so far so good internet is working fine
The update did fail to install a few times over wifi but I got it to sucessfully install after I turned off my nighthawk wifi extender EX7300
I updated from V1.0.4.18_10.1.49 to V1.0.4.28_10.1.54 and noticed I had to enable the smart connect feature again after the update got installed
Other issues are reported on this thread that I didn't experience
I opened this discussion for internet access issues with V1.0.4.18_10.1.49 and after I installed the latest firmware V1.0.4.28_10.1.54 my internet access issues (with standard parental contols enabled) seem to be fixed.
Cverneuil
Nov 08, 2018Aspirant
I've recently received a new unit after my previous units WAN port went out. The new unit is 2 weeks old and recently started having intermittent internet issues. I thought it was the firmware too. I've gone back to 1.0.3ish and still have problems. I have no parental controls, only default settings and a few address reservations. I've tried numerous factory resets with multiple FWs and have not found one that keeps me connected. Haven't done a FW update before it started wonking out either. I've been baffled by this and seems a lot of others are too.
IrvSp
Nov 09, 2018Master
Cverneuil, this thread is for an R8000. If that is not what you have (you listed R9000 as the router) then I suggest you open a NEW TOPIC as people might not see your post as this topic is now even marked SOLVED.
If you DO have an R8000, get the new firmware released a day or so ago. It might help. Go to SUPPORT, put in R8000, and then DOWNLOADS and you'll see it.
