fxv300
Jan 18, 2021Aspirant
No internet access
Occasional dropouts with "No internet".....good signal in location, a router reboot usually fixes.
Just found new firmware
Current Firmware Version 1.0.2.64
New Firmware Version 1.0.2.82
Has anyone tried this out ? 1.0.2.82
Cheers
Frank
I'm on the .82 without issues.
What modem/gateway is it connected to?
When it drops, is it all devices? just wireless devices? Wired devices?
- fxv300Aspirant
Problem is happening to many devices, but randomly. Yesterday had the issue with a laptop located in the same location which worked the day before. Rebooted RAX20 and it worked fine afterwards. Gateway is via a Virgin Media Hub3 setup in modem mode. When that happened about 16 devices were working fine in the rest of the house. I will update firmware and see what happens. This problem was happening much more frequently previously on the 5G WiFi.
I will probably setup the devices with a "assigned IP address".
Thanks for the feedback.
