helpmeplease12
Dec 13, 2021Tutor
No internet after firmware upgrade and factory reset R7000
Hello! I recently upgraded my R7000 to the latest firmware (1.0.11.128) as of last night and per recommendations, performed a factory reset on the router, including powering off my modem, waiting f...
Dec 13, 2021Guru - Experienced User
Push and hold the wifi on/off button for 2 seconds.
sometimes that gets hit while people troubleshooting devices.
- helpmeplease12Dec 13, 2021TutorThank you for the reply! I just tried turning the wifi button off and back on and there was no luck. Cannot even find my network in my wifi settings on my iPhone now.
- plemansDec 13, 2021Guru - Experienced User
Know anyone with a laptop/pc you can plug into the router to check if its working as well as what its ssid/password is?
They also make usb/ethernet adapters.
When you reset, did you push and hold reset for 7-15 seconds while powered on?
If so, the wifi should be the default ssid on the sticker.
- helpmeplease12Dec 13, 2021TutorI did reset while it was on and held the button for 15 seconds.
I don’t have a way to hardwire test it, if I have to go out and buy a usb/Ethernet port I might as well just exchange the router and go with Google Nest
