helpmeplease12
Dec 13, 2021Tutor
No internet after firmware upgrade and factory reset R7000
Hello! I recently upgraded my R7000 to the latest firmware (1.0.11.128) as of last night and per recommendations, performed a factory reset on the router, including powering off my modem, waiting f...
helpmeplease12
Dec 13, 2021Tutor
Thank you for the reply! I just tried turning the wifi button off and back on and there was no luck. Cannot even find my network in my wifi settings on my iPhone now.
Dec 13, 2021Guru - Experienced User
Know anyone with a laptop/pc you can plug into the router to check if its working as well as what its ssid/password is?
They also make usb/ethernet adapters.
When you reset, did you push and hold reset for 7-15 seconds while powered on?
If so, the wifi should be the default ssid on the sticker.
- helpmeplease12Dec 13, 2021TutorI did reset while it was on and held the button for 15 seconds.
I don’t have a way to hardwire test it, if I have to go out and buy a usb/Ethernet port I might as well just exchange the router and go with Google Nest- plemansDec 13, 2021Guru - Experienced User
Have you tried using a different device?
Not sure what else to tell you. there limited ways in which we can help if you're not willing to hardwire into it and you can't connect via wireless.
- helpmeplease12Dec 13, 2021TutorUgh I’m an idiot and forgot the network name would be reset after resetting the router. Not my brightest day. Things are back up and running after the reset for 15 seconds and making sure I’m connecting to the default network name!
Glad you got it back up and running!
