helpmeplease12
Dec 13, 2021Tutor
No internet after firmware upgrade and factory reset R7000
Hello! I recently upgraded my R7000 to the latest firmware (1.0.11.128) as of last night and per recommendations, performed a factory reset on the router, including powering off my modem, waiting f...
helpmeplease12
Dec 13, 2021Tutor
I did reset while it was on and held the button for 15 seconds.
I don’t have a way to hardwire test it, if I have to go out and buy a usb/Ethernet port I might as well just exchange the router and go with Google Nest
helpmeplease12
Dec 13, 2021Tutor
Ugh I’m an idiot and forgot the network name would be reset after resetting the router. Not my brightest day. Things are back up and running after the reset for 15 seconds and making sure I’m connecting to the default network name!
- plemansDec 13, 2021Guru - Experienced User
Glad you got it back up and running!
