wernd
Apr 06, 2020Tutor
No Internet connection after factory reset
 I had been having issues with my internet connection and wasn't sure if it was my router or ISP mode. My ISP replaced my router. in the meantime i reset my Nighthawk to Factory. Now when i plug the W...
- Apr 07, 2020
the windstream T3200 has an integrated router. try switching the netgear to AP mode. (access point). That why you only have device acting as router on your network.
Apr 06, 2020Guru - Experienced User
What isp modem are you using?
firmware on the nighthawk?
