Nisko555
Apr 28, 2022Initiate
No Internet Connection (Netgear Nighthawk Router R6700v3)
I am using a Motorola Modem and a Netgear Router AC1750 with no problems. I wanted to try a new router - so I purchased a Netgear Nighthawk R6700v3. I'm using the same Motorola modem and connected ...
Apr 28, 2022Guru - Experienced User
what motorola modem is it?
Try this.
Disconnect everything from the modem and the router (even coax from the modem).
Power them down.
Leave them off a couple minutes.
Connect coax back to the modem and then power it on.
Wait a few minutes.
then connect the modem to the router (lan port on modem to wan port on router)
Power the router on.
Wait a few minutes.
Attempt setup of the internet connection
- Nisko555Apr 28, 2022Initiate
Thank you for your response!! The Motorola modem is model: MB7420 (certified by COX cable - my ISP). I'm connecting the yellow port on the modem to the yellow port on the router. I don't understand the difference between the LAN port and the WAN port. The only CAT port on the modem is the one yellow. There are five CAT ports on the router - one yellow and four black. I'll try your suggestion as soon as I can (might be tomorrow). Thank you.....
- plemansApr 28, 2022Guru - Experienced User
good luck! Hope it works!
