Nisko555
Apr 28, 2022Initiate
No Internet Connection (Netgear Nighthawk Router R6700v3)
I am using a Motorola Modem and a Netgear Router AC1750 with no problems. I wanted to try a new router - so I purchased a Netgear Nighthawk R6700v3. I'm using the same Motorola modem and connected ...
Nisko555
Thank you for your response!! The Motorola modem is model: MB7420 (certified by COX cable - my ISP). I'm connecting the yellow port on the modem to the yellow port on the router. I don't understand the difference between the LAN port and the WAN port. The only CAT port on the modem is the one yellow. There are five CAT ports on the router - one yellow and four black. I'll try your suggestion as soon as I can (might be tomorrow). Thank you.....
Apr 28, 2022Guru - Experienced User
good luck! Hope it works!
