HLMSPL
Jun 28, 2020Aspirant
No internet connection using wifi 5g network
Router firmware v1.0.11.102. W10 64 bit os. Intel Dual Band Wireless-AC 3165 network adapter. On separate occasions I use both the 2.4g or the 5g wifi network to connect to the internet. The 2.4g...
- Jul 06, 2020
A reset of the router fixed the problem. I should have thought of that when I did the power off/on of all the components. Thaks to everyone who responded.
Jun 29, 2020Guru - Experienced User
Install version 1.0.9.42 of the firmware to the R7000, factory reset it, and then reinstall it. Disable auto updates.
See if that works.
