HLMSPL
Jun 28, 2020Aspirant
No internet connection using wifi 5g network
Router firmware v1.0.11.102. W10 64 bit os. Intel Dual Band Wireless-AC 3165 network adapter. On separate occasions I use both the 2.4g or the 5g wifi network to connect to the internet. The 2.4g...
- Jul 06, 2020
A reset of the router fixed the problem. I should have thought of that when I did the power off/on of all the components. Thaks to everyone who responded.
Jun 29, 2020Guru - Experienced User
Install version 1.0.9.42 of the firmware to the R7000, factory reset it, and then reinstall it. Disable auto updates.
See if that works.
HLMSPL
Jun 29, 2020Aspirant
Thanks for your reply. That will leave me vulnerable. Right now with an identified exposure out there prior to the most recent update I'm not inclined to go back versions and leave auto updates off. Even if that works I won't be leaving it in that state.
