Schutzmannfam
Jun 04, 2021Aspirant
No internet connection
After getting Fiber hooked up my router won’t connect to the internet. It will connect to the network but not the WiFi. I have tried rebooting the router but no luck. The guy installed the fiber and p...
- Jun 04, 2021Ok fixed it. Held the reset button in for 30 secs. Then got on my nighthawk netgear app. Did a new set up and it connected to internet!!!! Before I was just resetting it by pushing it one time. Holding it in 30 secs resets it back to factory setting. Try this... hope it works for you.
Gi3
Hello. Sounds like same issue for me. Internet provider ran many tests. The issue is the ethernet connection. Modem is not connecting to router/netgear nighthawk. The modem doesn't detect it. Tried other ethernet ports with no success. Hoping someone here knows a solution.
- SchutzmannfamJun 04, 2021AspirantOk fixed it. Held the reset button in for 30 secs. Then got on my nighthawk netgear app. Did a new set up and it connected to internet!!!! Before I was just resetting it by pushing it one time. Holding it in 30 secs resets it back to factory setting. Try this... hope it works for you.
- microchip8Jun 04, 2021Master
You should use the Web UI at routerlogin.net or http://192.168.1.1 to configure a router after a factory reset. The app is very limited and can get things wrong
