Schutzmannfam's avatar
Jun 04, 2021
No internet connection
After getting Fiber hooked up my router won’t connect to the internet. It will connect to the network but not the WiFi. I have tried rebooting the router but no luck. The guy installed the fiber and p...
  • Schutzmannfam's avatar
    Jun 04, 2021
    Ok fixed it. Held the reset button in for 30 secs. Then got on my nighthawk netgear app. Did a new set up and it connected to internet!!!! Before I was just resetting it by pushing it one time. Holding it in 30 secs resets it back to factory setting. Try this... hope it works for you.
