divonc
Sep 13, 2017Tutor
No Internet on LAN Ports WiFi fully connectivity
I am stumped. I have full internet connectivity via WiFi but “no internet” via the hard wired LAN ports. Here is the summary: Both the R7000 and R6800 were fully functioning routers Previously had...
- Sep 21, 2017
Finally figurred it out - pretty simply. There was a non-valid hard-coded DNS address on the IPv4 Ehternet adapter. Everything cleared up when I removed it.
divonc
Sep 14, 2017Tutor
Here is the ipconfig data
Microsoft Windows [Version 10.0.15063]
(c) 2017 Microsoft Corporation. All rights reserved.
C:\Users\Main>ipconfig
Windows IP Configuration
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Link-local IPv6 Address . . . . . : fe80::45e7:c9b6:ba9b:4ac7%16
IPv4 Address. . . . . . . . . . . : 192.168.1.6
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
Wireless LAN adapter Local Area Connection* 2:
Media State . . . . . . . . . . . : Media disconnected
Wireless LAN adapter Local Area Connection* 3:
Ethernet adapter Ethernet 3:
Ethernet adapter Ethernet 2:
Wireless LAN adapter Wi-Fi:
Link-local IPv6 Address . . . . . : fe80::f8a6:f558:71a:4ca0%12
IPv4 Address. . . . . . . . . . . : 192.168.1.8
Tunnel adapter Teredo Tunneling Pseudo-Interface:
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:953c:1464:38e5:3f57:fef9
Link-local IPv6 Address . . . . . : fe80::1464:38e5:3f57:fef9%7
Default Gateway . . . . . . . . . : ::
C:\Users\Main>
C:\Users\Main>
C:\Users\Main>
antinode
Sep 14, 2017Guru
Looks ok to me.
Also ok, but if they'e both active at one time, then everyone could
get confused.
> The easiest explanation [...]
Clearly not what you're seeing. But one system with two interfaces
on the same subnet could be troublesome. What happens if you disable
the wireless interface (on the Windows system)?
