Jay924
Jun 22, 2019Tutor
No internet on R8500 when pc connected to CM1200
Hello all, I recently purchased a CM1200 modem and R8500 router in order to upgrade to Gigablast by Cox. Currently testing setup and it works flawlessly as long as my pc is hardwired to the R850...
- Jun 22, 2019
Many cable ISP allow only one device only issue one IPv4 address to one MAC address - sometimes the cable modems require a restart before other sysems can access the netwrok again. So either a PC, or the router.
schumaku
Jun 22, 2019Guru - Experienced User
Jay924
Jul 02, 2019Tutor
Schumaku,
I've tried your suggestion to no avail. Once both the R8500 and the pc are connected to the modem, the speed in my network drops and Wi-Fi connectivity issues arise. I know the R8500 is cloning the mac address of my pc and that is probably part of my problem. Should I use another device (laptop) that will not be hardwire to the modem? I do have another question, should the connection to the r8500 go into the port label as internet or one of the other ports when connecting the R8500 and pc off the CM1200?
Thanks,
Jay
- antinodeJul 02, 2019Guru
> [...] So either a PC, or the router.
> [...] Once both the R8500 and the pc are connected to the modem, [...]
Which part of "either" was unclear? A least one of us needs to read
this stuff more carefully.Visit http://netgear.com/support , put in your (modem) model number,
and look for Documentation. Get the User Manual. Read. Look for
"Connect Your Cable Modem to a Computer", where it says:Note: Your cable modem comes with a plug that covers the LAN 2, 3,
and 4 ports. You can remove the plug to connect a router that
supports Ethernet port aggregation. For more information, see the
cable modem's user manual.You have to admire the quality of documentation which tells you to
read the manual which you are already reading.
Where does it say that you can connect multiple devices to themodem's LAN Ethernet ports?
Connect the modem LAN 1 port to the router WAN/Internet port.
Connect other devices to the _router_. (Leave the unused ports on the
modem unused.)
> [...] I need pc and R8500 connected to CM1200 since router will be in
> another room in the future. [...]That's too bad, because it won't work that way, as you've
demonstrated. Run more cable?- Jay924Jul 02, 2019Tutor
Antinode,
Thanks for the info, I came to realization that what I wanted to was not going to work after reading the product description page and another post on the CM1200. Since I will be running a cable back into the office, what switch would you recommend?
Jay
> [...] another post on the CM1200. [...]
Thanks for the helpful link?
> [...] what switch would you recommend?
Generally, for eight ports or fewer, I lean toward the cheapest piece
of (gigabit) Chinese junk I can find at the local MicroCenter store on
any given day. If I'm in an extravagant mood, I might splurge on a unit
with a metal case. (Slightly less likely to get pulled off the shelf by
its cables.)
