15charactrlimit
Feb 24, 2021Tutor
No Internet on Second Router
I'm using an XR300 as my primary router and an R7000 as my secondary router. They're bridged together with a long ethernet cable so that I can extend my internet connection to a nearby building. I've...
- Feb 25, 2021
>Which IP Address?
The LAN IP Address. I didn't think you could change the other one anyway.
>RTFM Failure?
I tried the method in the manual, but that's quite a bit different. It didn't end up working for me. I ended up just factory resetting both routers and then changing the settings to what I had them as before, and that worked for whatever reason.
Anyway, thanks for the insight and I think I'm all set at least for now.
antinode
Feb 24, 2021Guru
> Secondary Router (R7000):
> - IP Address set to 192.168.1.2
_Which_ IP address? A router like this normally has two IP
addreses: one for its WAN/Internet interface, and one for its LAN
interface.
> Any ideas on what might be wrong [...]
RTFM failure?
> [...] and how I can fix it?
RTFM?
Visit http://netgear.com/support , put in your model number (R7000),
and look for Documentation. Get the User Manual (at least). Read.
Look for "Set Up the Router as a WiFi Access Point".
Because you've been fiddling with it, it might be a good idea to do a
settings reset on the R7000 before configuring it as a WAP. After that,
you might need to lie to it a little to get it past its set-up wizard,
so that it'll let you do what you want with it.
15charactrlimit
Feb 25, 2021Tutor
>Which IP Address?
>RTFM Failure?
