ehlersgrub123
Feb 03, 2018Tutor
No internet output
I have a nighthawk X6 router. If I connect with a LAN to the internet modem I get good wifi and internet. If I connect the internet modem to a Netgear FS105 and then connect a LAN to the router I g...
- Feb 04, 2018
Too bad it has to work that way. Looks like I will have to run two cables from the basement to the router which will be on the second floor. One for input to the router and one back to the switch. But, thanks again.
antinode
Feb 03, 2018Guru
> [...] If I connect with a LAN to the internet modem I get good wifi
> and internet.
Connect what with what, exactly? A "LAN" is a Local-Area Network".
Do you mean "with an Ethernet cable"? What, exactly is your "the
internet modem"? If you're talking about a wired connection, then what
does "wifi" have to do with it?
> LAN to the router I get no internet.
Still confusing, but, generally, one would connect only the router
(WAN/Internet port) to an "Internet modem" (whatever that really is),
and a switch like an FS105 would be connected to a LAN port on the
router.
What, exactly, are you trying to connect to the Internet? (Wired
computers, wireless computers, ...) Are there not enough LAN ports on
the R7900 for all of your wired devices?
An FS105 is a 10/100MHz switch, which makes it slower than the
10/100/1000MHz (gigabit) LAN ports on your R7900. (Unlike, say, a
GS105 or similar gigabit switch.) If you have more than one old/slow
wired device, then it might make some sense to connect those to the
FS105 (and one of its ports to an R7900 LAN port).
> Suggestions?
Do more description and less analysis. Do not invent and/or misuse
technical terms ("LAN"), when a simple description ("cable") would be
clearer. Provide an accurate, detailed description of your equipment,
and your actual goal, rather than ask why some arbitrary/goofy
arangement of equipment is not working as expected. A typical cable has
two ends; when describing a cable, say where both ends go. A router may
have many ports of different kinds (LAN, WAN/Internet). "connect a LAN
to the router" conveys much less useful information than, say, "connect
my Windows laptop Ethernet port with a cable to a LAN port on the
R7900".
- ehlersgrub123Feb 03, 2018Tutor
OK. Sorry for the loose terms. I have an FS105 switch connected to an fiber optic modem ( where the internet comes into my house) via an ethernet cable. Also connected to the FS105 via separate ethernet cables are a desktop computer and the Nighthawk X6 AC3000 router. I have very good internet conectivity on the desktop. I had wifi signal connection from the laptop to the router but no wifi internet service . Now I must state that after messing around for about an hour and getting no internet through the wifi I made my first post. Well, lo and behold, it somehow is now working. Is it possible that the "slow" characteristics of the FS105 made it take so long for the router to recognize the internet signal? The reason I have the FS105 between the modem and the router is that my desktop computer, printer, smart TV are all in the basement and I want the router on the second floor to get good wifi coverage outside the house and to a shop a couple hundred feet from the house where one of my laptops will be located. I'm guessing I should have gotten the GS105 instead. Thanks again.
- antinodeFeb 03, 2018Guru
> [...] I have an FS105 switch connected to an fiber optic modem ( where
Is the (unspecified) "fiber optic modem" also a router? If not, then
connecting a switch to it might be very unwise. If so, then you may
have problems in some cases from cascading the two routers.
> [...] Is it possible that the "slow" characteristics of the FS105 made
Probably not, but any change in the wiring could confuse some
devices, especially when two routers are involved.
It would be more appropriate for the devices with gigabit ports.
> [...] The reason I have the FS105 between the modem and the router is
> I want the router on the second floor [...]
If the "fiber optic modem" is also a router, then it might make some
sense to configure the R7900 as a wireless access point. That would put
everything on one big LAN, which would eliminate any two-router
problems. Visit http://netgear.com/support , put in your model number,
and look for Documentation. Get the User Manual. Look for "Use the
Router as a Wireless Access Point".- TerryPhFeb 03, 2018Virtuoso
Router as a Wireless Access Point".This is in my opinion, the best approach for your big houre.
